Gen. 1 Turbo values
RichD1
Guest of the Club
Thinking of buying a Gen1 Turbo, but are they still depreciating our have they bottomed out now?
I've been looking for one for the last year & i think the 997's have increased slightly in the last 6 months, 996's even more so, not easy to find a good one with no corrosion though IMO so make sure you get it inspected.
Karl
The short answer is that basically they have stayed about the same for the past two years at the lower ed of the market and probably due to the 50% increase in 996 values in the same period. You can occasionally find the odd decent 2005/6 Tiptronic cars c 60k ish miles just under £40k and a manual ones from £43/4k which is where they were two years ago. The only thing is that the newer cars 2007/8/9 Gen 1 cars have dropped into the mid to late £40's i.e lost -5% to -10% and the low mileage ones just into the £50's So its best to spend a few k more for lower mileage and newer car as the Gen 2's start at £60k.
Gen 1 is best turbo by far, it will be a future classic because of its engine, the last of the metzger race engines.
Now 996 turbos are on the climb and only £10k below a 997, this will prop up the 997 values for sure.
if you get on board now and buy the right spec with manual box, you won't lose a penny!!!
Karl
corrosion?!?
Under the rear end, various parts are very susceptible to corrosion, 996 & 997, 997's are slightly more protected underneath.
Karl
Certainly on the 996 rear brace bars will lose their protective coating and corrode due to their exposed position - hope to get mine powder coated over winter months. Also, header and exhaust fixings get their fare share of the elements over the back wheels.
Yes, I was quite surprised to see the level of corrosion under my 997.2 when it was on the ramp. Largely superficial I feel sure but it doesnt look very good.
