Gen II - Boxster/Cayman - Issues Resolved?
- Thread starter Greg Park
ORIGINAL: Greg Park
Have all the RMS/IMS issues been resolved in the Gen 2 Boxster/Cayman?
Re-designed engine not to need a rear main seal (i.e. not resolved with better seals [
The RMS will stil be needed I think - or the gearbox connection will have to be via magnets or something [
SidewaysSteve
The RMS is needed to seal the crankshaft which is bolted to the flywheel then the clutch to the gearbox so it must have a RMS still. [
As far as I was aware like Mark said its the IMS thats been removed from the newer engines.
ORIGINAL: SidewaysSteve
Yeh seconded, I was thinking no RMS ??? WTF ! LOL
The RMS is needed to seal the crankshaft which is bolted to the flywheel then the clutch to the gearbox so it must have a RMS still. []
Someone mechanical tried to explain but i clearly misunderstood [
So Turbo, GT3, GT2 are not prone to leaking due to the dry sump and no IMS then?
Andrew Killington
IMS yes
RMS not necessarily
