Gen2 Dynamic Cornering Lights - Switching to European Driving
robertc@okw.co.uk
Set out to switch my lights over last night for european driving. Done it several times on the Gen1 997 - very easy with internal lever on the side of the lamp unit marked O-T.... 10 minute job....[:D]
Now for the Gen II car - removed the lamp unit as before, opened the back of the lamp housing.... oh God. there is a controller unit blocking your view into the housing and then a mass of wires and assembly parts.....[:eek:]
Back to the manual then... reading it... you have to remove the controller unit, and then find what I can only describe as the most discreet switch ever designed by man.... I stare into the unit.... dumbfounded.... the O-T symbol are now moulded on the outside of the lamp housing so do not help to identify where the switch is, only the direction to push...[:eek:] after five minutes I find a tiny spring clip on the side .... surely that cannot be it....? push it firmly, and up it pops... success.. [:D]
I will post some digital pictures when I switch the lights back, to help anyone else with these lamps...
Robert, glad you were the first.
If you could do some images, I'm sure it would be appreciated by many more to come..
garyw
