on the last couple of track days i've been on, i've felt that my C4S was a bit "floaty" in the corners than maybe i thought it should be, but not having another C4S to compare it to, i wasn't sure. however, last fri at my track evening, i was taken for a spin in a 996 turbo (so obviously same suspension, brakes etc) and it seemed to feel more planted in the faster corners, say at 70mph+.
now, my rear tyres do need replacing soon, but i'm pretty sure they're not the cause (is this correct?), so it looks like it maybe that the shocks are worn out (car has done 53k miles and they haven't been replaced) or the geometry needs checking.
plan of attack is to get new rear tyres, get geometry checked, then see if the situation has improved on my track day. if not, new shocks may be in order.
so, i have 2 questions:
1. is someone like my local porsche specialist (chelsea carrera, sounds like a pornstar!) qualified to check and adjust the geometry, or should i go to a specialist in it like centre gravity?
2. if i am going to have to fork out £1k or so for new shocks etc, is it worth just getting a suspension upgrade to lower it and firm it up for track use (i'll take the day to day ride comfort hit) and if so, what is a reasonably priced system and where might i buy it from/get it fitted?
apologies for the long post!
