George Elliott
For 4 years I have run a 944T, and I follow the theads here with inrerest. My 1989 car has 120k miles and all the running repairs that you know about, - my other half understands [
] the wise investments necessary to keep my 951 happy, and so my 951 has become known as my German girlfriend [8D].
My most recent mod today was to fit an adjustable voltage regulator, and after refilling the coolant and a five mile drive she's taken ill. I had improved dash lighting, faster wipers, better lights, then at the change up point in 3rd gear when one is pressing on - the engine ceased to produce power and the electricals all slowed up, slow wipers, dim lights etc.[&:]. Hard shoulder....
The engine attempts to run, but falters and dies if the throttle is touched, or dies eventually if left at tick-over. The battery has also lost its belly, going flat very quickly. I have tried a new battery and DME relay, - without success.
I have a specialist to talk to about it tomorrow, but any thoughts would be appreciated.
The pre-mod dash volt meter typically read 11.5v to 12.5v. When I set the adjustable one it read 13v on the dash, but I did note that across the battery terminals the reading on a Test Meter was 16.3v. (All readings are at tick-over). I did not measure the battery reading pre fitting the adj regulator. The engine was noticably crisper while it lasted.
George
fyi she was previously reg'd as ALS 56Y, which some of you may recall from 911&PW running reports years back.
also, I hardly know how to use this forum but here goes.....
George
