Getting worried
mas430
Car is a Tiptronic & its due in for the MOT soon. I am concerned about the
emission test as I have read that if its revved up in neutral to 3000+ rpm it will
cause damage to the Torque converter?
I can't see that there would be any problem, otherwise you you would have heard about it by now, with the amount of automatics around. If the engine is warm, then revving it to 3000 isn't an issue. I don't know what year your car is, but mine has a rev limiter which prevents it being revved above about 3500 in neutral anyway.
Relax, would be my advice.
Correct me if I am wrong, but you only fry torque convertors by having lots of resistance, stress and heat, IE boy racer antics by trying to pull through the brakes. Neutral with the parking brake should be fine.
*edit that was not in response to you Richard :)*
