Glue Recommendation
944 man
Id like to permanently reattach the foam pieces that are coming loose on the underside of my load deck carpet. Can anyone suggest a use once and fix it right product, please?
Just reattached mine, gorilla glue.
use very sparingly as it expands as it sets, but its superb stuff.
I've just used Evo-Stik spray contact adhesive to fit the new carpets to my 968.
Seems to do the job.
Thank you. I prefer the sound of silicone but sealer can be very hit and miss as an adhesive, so Evo-Stik it is.
Hi Simon
i have done this but never posted it on the thread there are a few problems
inside the foam is a sheet of what looks like polycarbonate this is a non porous substrate
gluing the carpet to the foam is easy but to stop it going again you must bond the foam to its self and seal the crack, this joint needs to be flexible using a glue that goes "hard" will cause the foam to crack again back to square one
I comsidered many options. Like covering the foam with trunk liner or fabric even flock spraying but in the end I used a liquid latex to fill gaps and create a flexible joint solid joint
it was very expensive and pink :rolleyes: but it did a fantastic job.......then I saw a perfect carpet on ebay so brought that
just tried to find the stuff on the web but couldn't see it, I'll look harder if your still interested
