Good idea??
steves944
&hashJust happened upon this
http://cgi.ebay.com/ebaymotors/Porsche-944-968-924-timing-belt-cover-clear-see-through-/200511557245?pt=Motors_Car_Truck_Parts_Accessories=item2eaf6b8e7d
Seems a sensible plan methinks? Or just a waste of money?
Kind of I suppose, although it only really lets you see the material condition of the belts and rollers. If you've changed them then you know this already and if not then you have to take the cover of to fit it anyway. Although it might let you see some out of the ordinary issues that arise with the belts and rollers.
Sorry to sound so gloomy on this but why would you want to check the condition of your timing belt? What does it tell you? Seems like a solution for which there is no problem. In any case the polycarbonate cover wont stay transparent for long. It wont take long for it to discolour and become opaque. Keep your money in your pocket, replace your timing belt in accordance with the replacement schedule and forget about it. Life is too short to worry about thing you don't need to worry about. It is a bit like the oil pressure gauge. The only reason people worry about oil pressure is because there is a gauge and they ponder over every movement and flicker of the needle. In cars i've had that don't have oil pressure gauges i've never even thought about oil pressure, let alone worried about it.
ORIGINAL: sawood12
Never a truer word said.
My Golf only has an oil warning light, I was going to fit a gauge but its still in its box.
