got any tyres recomendations?
- Thread starter Guest
Best advice is have a look at these links yourself.
http://www.tirerack.com/tires/tests/gy_f1_gs_d3.jsp
http://www.tirerack.com/tires/tests/testResultsMake.jsp?tireMake=Goodyear&x=19&y=12
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=MP
You can then decide for yourself. I'm very pleased with the deal I got and the tyres. They have transformed the car's handling, are quiet and grippy.
Have a look around.
Black80XSA
N rated then Pirelli PZero rosso or Dunlop SP9090s give good wet/dry grip, wear and noise balance.
Goodyear F1s or Yokohama AVS Sport (forget old stories of rapid wear rate) if you want to go non N rated.
The details for Bracknell Tyre and Battery are:
Bracknell Tyre & Battery Co.LtdUnit 1, Longshot Lane Ind Est, Longshot Lane, Bracknell, Berkshire RG12 1RL Tel: 01344 411323
Good luck. They are very quick and normally next day delivery. I arrived with 6 cars in front of me and left an hour later with all fitted etc.
Need4Speed
ORIGINAL: Black80XSA
Keep away from contis (the grip changes too markedly as they wear).
Yokohama AVS Sport are indeed N rated [N1 spec] / Porsche approved:
http://www2.uk.porsche.com/english/gbr/news/christophorus/0304/pdf/cpm_301_sommerreifen_engl.PDF
When I collected my car from Zuffenhausen, I was expecting to see either Contis/Pirellis/Michelin. I was a little bit surprised to see Yokohama's gracing the 18" Turbos! However, the customer delivery representative quickly dispelled any reservations I had with this brand. 3 years on and several Yokohama AVS Sport's later, I don't think I'd opt for different rubber unless I change cars.
Andy
I am presently running Contisport 205/50 ZR 17 (N1) fronts & Pirelli P6000 255/40 ZR17 (Y) Rears. I know mixing is a no no. Twas not me it was the previous owner, honest. Anway I just wanted to check that I at least have the correct tyre sizes. Can anyone confirm this for me.
'N' rated? Is this the speed rating?
Anyway it looks like the Eagle F1's are out. I was thinking about the Toyo Proxi's for all weather road driving. Can I go wrong?
Steve
P.S. I am a member.
C4 1990
Dave Wilkinson
The "N" rating is nothing to do with the speed rating. It is the sequential approval number issued by Porsche for tyres made to their approved specification and - according to Porsche - are the only ones recommended for fitment to Porsche models.
Not all tyre manufacturers submit tyres to Porsche for approval and only specific sizes are submitted for the current car range. Any tyres which were submitted for the 964 when it was in production will no longer be available anyway although you will almost certainly find some sizes approved for the 993/996/Boxster which WILL fit.
Personally, since I've got 18s on my 964 I was lucky to find the Yokohama AVS Sport which has been approved for the Boxster in the correct sizes for my 8.5/10 wheels.
Just to go back to the N number - it will be moulded into the sidewall of the tyre as N0, N1 N2 etc., the number being the sequential number for a particular tyre type. Each time the manufacturer submits the same upgraded tyre type to Porsche, Porsche will assign the next number. It is recommended by Porsche that you ONLY fit the same tyre type AND N number to all four wheels. Tyres assigned N numbers by Porsche are ONLY available in the correct Y or Z speed rating.
Hope that helps.
Dave
I fitted Conti Sports Contacts to my 944 Turbo and was really impressed with them. They transformed the handling in the wet and dry, and were also much quieter than the Michelins beforehand.
Steve
