I noticed a couple of electrical issues last weekend. Firstly, the intermittent wipe function is only intermittent for the first wipe, after that it just wipes at standard speed. Also, when you switch the wipers off, either from intermittent or standard, they don't return to the start position. So unless you time it right, they're left half way up the windscreen!
The other issue is less annoying but curious all the same. When i switch off the lights after they've been popped up, the lights go off but the actual units keep popping up and down until i pull the key out.
Any ideas?
Any ideas?
