devans
hi, have had a grinding noise coming from somewhere which is sending a vibration through the car. If I lay my fingers on the handbrake lightly, I can feel a vibration. Mind you I got the same response placing my fingers on the dashboard.
i have renewed both rear tyres, I have replaced front brake pads and brake discs. I have checked rear pads and discs and I have wire brushed and sanded the inside of the rear discs as sometimes they can corrode. I have also bled the brakes just in case. Not a full flush but just a simple bleed, rear brakes first and then front brakes.
the caliper pots seem to push back in flush with little effort, is just using pliers. Because they pushed in easy, I thought I could disregard rusty pots etc. Only thing I noticed was that the pots don't all seem to move together, is this correct?
people tell me it doesn't sound like a wheel bearing but I cant see anything rubbing.
noise does not occur when car is running stationary, it only occurs when the car is moving.
any ideas would be greatly appreciated,
thanks
thanks
