Groaning Noise on Start-up
RICH7105
Hi
I've an '89 944 cab and just after the engine starts-up there is a groaning noise that then dies away. It's at the time when the starter has just kicked over the engine. Does anyone know what this could be (?? starter related) ? The engine starts just fine..so hoping it's not serious.
Thanks for helping
Rich
Its probably the car saying "oh no, here we go again, I`m in for another damn good thrashing"
[:D][:D]
Can't be the wife, he said the noise died away [:D][:D][:D][:D]
Not unless he leaves on the drive!!!!
Just running for cover now
What sort of groaning? If it sounds a bit like a dying 'Moooooooooooo', it could be the oil pressure release valve. Usually happens when the engine has been running for a while at high revs and is allowed to come down to low revs (coming off a motorway, for instance), but could also happen on start-up, I guess.
If so, nothing to worry about. It will probably go away next time the oil is changed.
ORIGINAL: xenon
ABS pre-charge pump.
That would be my guess, sometimes I forget the car does this, I am sure my 968 does the same and its always a little surprise if I haven't driven the car for awhile.
ORIGINAL: xenon
Would be my guess too - if it occurs just as you pull away as opposed to a finite time after the engine starts.
Otherwise I'd guess its a noisy starter drive pawl bearing - if it occurs just as the engine kicks into life, the starter pawl gets kicked out from the flywheel ring-gear, and the starter spools down. This should be over very quickly after the engine starts.
Car has to start moving first for the ABS to check itself.
Rich said it is immediately after the starter is engaged and could be a sticking starter bendix however..........does the noise (sounds like a coffee grinder) come from the r/h side of the drivers footwell, if it does then its the ABS system check which should only operate as you start moving.
Thanks for all the useful suggestions - Have determined the following ..
1. It's not the wife - although if she knew what the suspension refresh really cost she might well groan....
2. ABS was ok
3. I thought Porsches were built to thrash - so it can't complain, surely..
Turned out to be the starter motor not disengaging.
Seriously thanks all for your help
Rich
