ground clearance 911 turbo??
- Thread starter Guest
There is an option to specify it 20mm lower with the sports suspension (i.e. 70 mm clearance, GT3 style) but I've not seen one that low and it doesn't seem a common option.
Bear in mind that the aero kit reduces clearance at the front even more, even though the suspension is unchanged. The front lip juts out more and is lower.
As standard, speed bumps are OK as long as you take it steady (walking pace) although ramps require some care, like driveways, forecourt entrances where you cross the pavement, etc. The standard front lip is softish and easily replaceable (4-6 screws), if you do scrape it.
If you parallel park, then stop short since the front is lower than the kerb and will hit it.
