Vic Rattlehead
Morning all.
After a good weekend of welding and grinding I've come to the conclusion that the nearside wing on my Turbo is beyond repair. Looks like it's had a previous bad repair as all of the bottom is completely distorted. Had to grind out a good amount of filler which then revealed a crudely tacked in patch covering a massive hole. There's even surface rust appearing underneath the underseal.
So I have one good offside wing which literally needed 1 small patch welding in to where the lower bracket fell off. But good second hand steel wings are hard to find.
Has anyone had any experience with the GRP panels from Teilecar? Are the fit and panel gaps good or do they need a lot of fettling and glass adding in to make them good? A search on here turns up one mention saying they're pretty good but that's all. GRP would pretty much future proof the whole front end. But obviously takes away the originality of having steel ones.
Or do I bite the bullet and buy a new OEM item from Porsche?
Thanks in advance.
Russ
Thanks in advance.
Russ
