Gunk in my oil!
- Thread starter skendrick
A good heat through might clear it.
Timely reminder for everyone to keep coolant changes up to date; i assume the 996 needs the two year
interval; or five year if you have confidence in long life.
Haven't even collected mine yet so will bow to anyone's superior knowledge.
Tim
2003 996 Cab (hers)
1992 928 GTS (mine)
thirteeneast
ORIGINAL: skendrick
Hi all,
Topped up my oil today and found yellow gunk at the top.
Is it what i'm dreading, head gasket?
I have checked my oil pressure and it doesn't seam to lose any pressure!
Any thoughts/
I would say you will be lucky if its only a head gasket.
Is it difficult to remove the filler cap with the engine running?.
If there is no trace of oil in the water, and vice-versa, I wouldn't worry.
skendrick
Big relief though, thanks guys!
I do have a smell of oil from the drive side rear wheel arch. Ihad this on my 964 and that turned out to be perrished pipes, so I will get this checked out at Northway!
