Gurgling Noises!
This might be areally silly question but.... can anyone confirm if the 'gurgling' oil noises at start-up should continue throughout driving? I'm noticing this especially when idling ahilst stationery more than when driving. Also - does the oil level indicator normally fluctuate around half-way or should it be pointing higher? Maybe my two issues are connected??
Apologies if these are fundamental issues...just got my first 911 following a 30year desire!
Any advise gratefully recieved.
Cat
I don't get gurgling noises at start up and I don't think you should but it isn't the end of the world fortunately. On my car you only get these noises once the thermostat is opened in the rh front wing and the oil is flowing freely; then it gurgles away like a good un. Does your rh front wing get hot at all? Faulty thermostat is a strong possibility if not and easy to diagnose.
The oil level indicator means nothing until the oil is hot, the car is stationary and has been for at least 30 seconds and, most important of all, the motor is running. In these conditions, the indicator should give a meaningful reading and ideally will be at the half way mark or higher. To be safe though, when you do this check, take the opportunity to check the dipstick as well and this ought to show you the relationship between the gauge and the actual level in the oil tank. Don't turn the motor off when you do this. (And mind the belt and pulley which will grab anything dangling....). You are looking for the oil to show at least half way between the marks - less is OK but try to at this level or slightly higher - and don't overfill either. Clean oil is a complete bugger to see on the dipstick so you will need to practise a bit. When filling, keep the motor running, add some oil then dip the tank again after a minute or so - don't chuck in a litre at one go.
On my car, the gauge is very accurate and I tend to rely on it most of the time, only bothering to check the tank about once a month irrespective of what the gauge says (unless it reads very low obviously). If you find your gauge says high but the dispstick says otherwise, you will need to check the tank more often. Common practice seems to be to run with the tank filled to the half to three quarters level on the dipstick.
And go the titanic 964 site and John Miles smartgroups site for more info and meaningful (and sometimes pointless) information and 964 banter.
Hi Richard,
Thanks for the advice, I'll do some checks. I'm close to Northway where I live if I need any works doing!
Cheers again!
Gurgling is ok at start up, most get this, its just the oil being coldish and pumped around the system and back to the oil tank. You'll probably notice it more on a slightly colder day.
kevin.
No worries Richard,
Cat, you might want to visit the Rennlist forums as well, some very sage like advice will hence be ofeered......
kevin
Hi Kevin,
Thanks for the extra info. Thanks to Richard too.
Just on your website at the mo. Like it a lot, we have almost identical cars...must get the 'avatar' thing sorted once the digi pics are done!
Anyway, thanks again.
Cat
Kevin
The nearest thing to a gurgling noise that I have ever encountered is the rear spoiler going up or down. Some people say it like a coffee grinder, but "gurgling" is a good description of the noise it makes on my car.
Oil level on 911s really is, as Cat's posting shows, a case of RTFM (if you have a computing background): consult the manual and read the conditions and limitations of the accuacy of both the oil meter and the dipstick. I have to say that I run my 964 for about 12 to 15k miles a year and never look at the dipstick at all because the meter seems fine, and it hardly uses oil anyway.
HTH
Alistair
