Hand brake adjustment
Bazzer
Hi Chaps once again, I have now moved on from the engine department and gone on to the hand brake, could some body give me an idiots guide to where I may find a so called cable equalizer adjuster, I have fitted new shoes and would now like to set the cables.
My haynes manual points me to inside the cockpit, is this correct, if so where might it be hideing as I have looked pretty much every where, bar the right place!.
Thank's for the help I know I am about to recieve!!!!!
Baz
The cable equaliser is on the back end of the handbrake, probably under your Automatic Heater control, if you have one, Each rear wheel handbrake cable is seperate, this is where they join the handbrake. The rear brake drums have a hole in them on the wheel mounting face to put a screwdriver through to adjust a ratchet cog between your brake shoes, you can adjust them nearer or further away from the inside surface of the brake drum.
As Bernard says, the cable also has adjustment on the threaded end of the cable as it goes into the hub.
Thank's guys in the past I have adjusted the shoes soley on the drums but never quite got it right, when looking in the manual it says about this adjuster in the car but have looked by the heater control and cannot see one, so as you said Phil it probably has'nt got one,, this makes life a little easier.
Many thanks for the info
Baz
Sorry,
I should have clarified in my 1st post, the part on the end of the handbrake is not an adjuster, its just an equaliser/compensator, so when you pull the handbrake up it pulls both individual cables at the same time.
The cables at the handbrake end have loops to hook onto each side of the the equaliser.
Im probally a bit late to be of any use, but I did my hand brake a few months ago, here are a few useful tips
When you replace your shoes, check the spring bits where the cable goes through, mine were warped so basically when you pulled the hand brake on full nothing would happen on one wheel - assuming allgood, set the shoes about four clicks from the drum, and then operate the handbrake a few times to take up any slack in the cable.
With the handbrake released, look at the "centralising bar". This is at the back of the handbrake, and you will have to take off that heater box which sits over the handbrake (mines a 79). Ok have a look at the bar, the idea is two adjust the two nuts near the brake capliper (At the back of the brake disc cover), such that the equalising bar is central before you pull the cable, and as you pull the cable. I then check that the wheels are both locked at say 4-5 clicks, and at 2-3 clicks feels about the same (turn the wheel).
I spent probally 10 hours adusting those damn cables, i even put it all back together a few times and still no good, i finally found that those little springy things (sorry not vey techincal) where the cable goes through to "pull" on the shoes, were quite unserviceable. When I replaced those (I repaired em actually), then the handbrake worked properly staright away, so to cut along story short, if your having trouble getting the balance right, after trying everything - i.e one wheel is locked and one is slack, or the wheels locks and when you release the cable still feels tight, then this is probally where the problem is (assuming the cables are good).
Hope that makes some sense
Luke
