Had the S2 in for MOT today and the parking brake was failed because of below requirement efficiency. The guy at the MOT station can only measure 86kg on each of the rear brake when the brake handle wad pulled to its maximum clicks (3 clicks). I will bring it in for a check and adjustment tomorrow.
I had the same problem in the last MOT where the garage adjusted them last time and then passed the retest. Just wonder if there is a known issue/problem with the parking brake on S2s and how often do they need adjusting. Please advice.
