cococola
My handbrake works okay however I find that the L/H side handbrake linkage(at the bottom of the shoes)rattles.
The handbrake cable going into the hub body on the L/H side is slack causing the linkage/actuator to rattle over bumps.
Is this down to an adjustment?It would appear that the handbrake is less effective on this side.The adustment on the shoes appears to be correct and if I adjusted anymore,the brakes would bind.
If I adjust at the handbrake handle end would it adjust the problem side and also tighten the cable into the body to stop the rattle?
