handling problemes at hight speed
Konstantin
Hi everybody,
I own a C4 92 it has original shocks ,green H&R springs quite lower at the front, I have a strud bar on the front, the engine produce about 275 HP I also have speedline rims and the camber is 1/3 deg R 1/4 left as it will touch , also the car doesn't have undertray engine;at arround 130 the car feel instable there is a good dead zone on the stiring I would have thought that it could do on a straight line 150 ??? any ideas how to improuve it .
many thanks Konstantin
Original dampers? As in the dampers supplied with the car from the factory?
I'm not a great expert but most dampers are screwed by the time they have done 50,000 miles. The dampers have the job preventing the wheels oscillating with the shocks absorbed by the springs, in other words they absorb the energy from the springs damping the oscillations. If they are knackered every bump/imperfection you encounter will cause the wheels to oscillate for a time, breaking the wheel's contact with the road and unsettling the car.
