Harness/cage fitment
nineonetoo
Hi Guys
Can anyone please tell me if the 964RS has factory fitted pick up points for 6 point harness fitment? Ive had a quick look under the seat but cant really see anything....
Also is there the facility to bolt a roll cage straight into the car? if so which brands are recommended?
cheers
Doesn't have the points for a six point harness - they were originally set up for 3 point racing harnesses - but you can have the points put in, I and many others have.
Heigo for bolt in cage - do a search on heigo in this forum and you will get Ollies thread on his.
Maybe some more info in one of my old threads...
http://www.porscheclubgbforum.com/tm.asp?m=159899
There IS or should be points for crutch belt under the car. take a look under the seat for two plastic blanking plates protruding out just ahead of the dme about six inches apart. if you look under the car the points should be seen there but may be covered by the plastic blanking plate.
