Harness mounts
911kev
I have bought a pair of Sabelt harnesses to fit in my C2. How do they mount to the side of the seats. I see that Brey Krause do a bracket that fits both side. Is there an part available from an OPC?
http://www.porscheclubgbforum.com/tm.asp?m=484826
This thread may help, although its more related to RSs. there seems to be 2 types of mounts, the eye mount and the simple bolt and lug. The bolt and lugs are turned into eye mounts, by screwing eye bolts in (should come with your harnesses). However, it assumes you have threaded holes for your mounts. Again, if you dont, your harness should come with threaded plates to weld on to the car. I *think* the 2 lower seatbelt mounts can also be used. If the fittings are tight with the seat runners, there are brakets that twist and bend that you can use too. Who ever sold you the harnesses should help. I purchased mine for MSAR, who I cant recommend enough for the personalisation of service they gave. Also, you can get cheaper harnesses by buying last years (as you lose a year on the FIA status), which probably wont bother you unless you are racing.
Kev. If you go for the Brey Krause ones, make sure you get the small tunnel side mount - ask me how I know [:(]
