Harness question
Ian964
I want to replace the 6-point harnesses in my cup car, as they're rather old and showing signs of wear. Looking at the Schroth Profi-II 6, is the version they make specifically for the GT3 suitable? The shoulder straps need to wrap round the roll cage, the lap belt ends bolt in, and the crotch strap hooks on to two eye bolts.
Should be fine, but I found with the Schroth tear strip (if it's ripped it's been used in anger!!) I could not get it tight enough for me over the cage so have run the shoulder straps to eye bolts in the rear shelf.
ian
schroth Profi-II-6 V-strap Clubman Harnes (Code: SCH91152-2 from GPR 01327 855585)
£240 for the pair
fit on the rollbar no problem (i'm obviously carrying a bit more padding than Mel...[:mad:]) only change was to change the lap belt mountings to eye bolts rather than the bolt in version of the originals
lovely and comfortable
I put in the 6 point version of Schroth Profi III FE asm, no problem, everything fine. Shoulder straps around the roll cage, eyebolts for the rest. 30 min work.
Rgds
Hacki
