Harness?
- Thread starter channella
ORIGINAL: JCB..
not to mention it's occupant?
Realise the seat might suffer, but don't understand this part. Can you elaborate?
Another alternative is the cg-lock which claims to give a normal inertia reel belt 80% of the benefits of a full harness
Check out www.cg-lock.co.uk
I wanted to spec them after driving a Boxster fitted with the bucket seats on a "test drive plus" but ~ÂŁ900 for seats + ÂŁÂŁÂŁÂŁÂŁÂŁ for full leather was just too much [:'(]
I have seen on US forums harnesses fitted to standard or sport seats though, so a search on http://www.ppbb.com/board/986board.htm the likes of might be in order.
JCB..
Non-member
I assumed that a harness went with a proper 'bucket' type seat rather than a normal car seat. You tend to sit in a bucket seat rather than on it. Apparently you can get them for normal seats.
Carl.Young
The only downside I've seen is that they tend to break or fall apart rather often...
You attch the shoulder straps to the roll bar - you have to take the mesh thing out if you ar using them. The lap straps are attched using brackets bought from an American co. I think they advertise in Porsche & 911 world. This means you can use the inerta reels during normal road driving as. I also got a mounting bracket for a fire extinguisher which fits immediately in front of the passenger seat
I'll try and get some piccy's to post
Carl.Young
ORIGINAL: WILLR
I've ordered one anyway to see what it's like.
ORIGINAL: Cary Blackburn
You attch the shoulder straps to the roll bar - you have to take the mesh thing out if you are using them.
I've got the GT3 seats and the 6 point harnesses in mine. The belts fit around the roll bar - but I have been able to use the mesh rollhoop inserts without any problem. Are you sure your's don't fit?
