Hi everyone, I hope you're all well.
After a summer of messing about with suspension and steering issues, I'm now trying to solve a problem with the hatch. It only opens intermittently. I have checked the tecnical articles and theybdont quite describe my issue.
GND from the motor is all good. I've also replaced the motor with a spare: same problems.
Basically, it works from both switches intermittently. Sometimes boot and footwell switch work and the motor turns no problems, sometimes nothing (no motor turning). The interesting thing I've noticed is that sometimes it works when the ignition is on vs off i.e. it isn't working and then I switch the ignition to position I and it works.
I've looked over the wiring diagram, and the only GND I can see is from the motor, which shows 0 resistance and is a nice clean contact. I'm thinking, are the two switches linked at all? Could it be a common fault on one or the other switch? Am I missing a GND on one of the switches maybe? Could they both just be faulty switches?
Any help is appreciated as always.
