VYY930
Hello,
I have a niggly noise which bugs me upon starting the 930 which I dont think is a major issue. Anyone help me determine what this noise is please?
Ok, when I go to start the car the starter motor spins up fine starts the engine. After the engine starts a noise can be heard for about 3 or 4 seconds (sometimes less). The noise sounds like the same noise you get when your starter motor is not disengaging properly, You know the kind of sqeal I mean I'm sure. Anyway, I thought it was the starter motor causing the noise so I got hold of a new one and had it put on the car. Thinking my troubles were over I collected the car to find the car has the same noise.
What could this be? Is is possibly a fuel pump? It definately sounds like a motor of some kind but only found upon startup. If the car has been running and then stopped and restarted it doesnt always happen. It can last up to 3 or 4 seconds as I said but sometimes not at all.
I might have to get a recording of it and try and post it on here some how if nobody can identify it!
Cheers for any help,
Chris
Chris
