Bonzo
Evening everyone ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Since I've had my 944, I've been trying to keep it watertight...
The problem has only ever been in the drivers' rear footwell, all other carpets have been dry.
Unfortunately, I think the leak has been there years- it's rotted the carpet, rotted the rear seat, turned all the trim screws green and done it's best to mist up my windows ALL the time!!
After a nights' rain, I'd have a cm of standing water in the rear footwell... [:-]
Anyway, I'm not the sort to put up with that so this is what I've done/checked-
Sunroof
* Cleared all four drain tubes.
* Replaced the inner and outer roof seals.
* STUCK the inner roof seal in place with dum dum.
Fuel filler neck
* Took out the big rubber moulding (that surrounds the cap itself) and un-blocked drain hole.
* Took out the small drain bung in the bottom of the filler appature and unblocked it.
* Made sure the metal pipe from the drain bung was clear and in the drain bung properly.
* Ensure the Drain bung hose was correctly fitted into the O/S Rear sunroof drain pipe (via a plastic 'T' piece).
Doors
* Removed both front door cards, cleaned away all dirt in bottom of door
* Unblocked door drain holes with welding rod.
* Re-sealed door plastic membranes.
Sills
* Cleared out drain holes (slits?) with welding rod.
Bulkhead
* Removed all leaves/ dirt from inner scuttle/ bulkhead and cleared drain holes at either end.
* Made sure the fan/ heater box was properly sealed to the inner scuttle panel.
Rear hatch/ Boot area
* Check sealing between glass and pressed metal frame (small drip here...)
* Re-built rear latch pin assemblies, checked drain tubes etc.
* Re-sealed rear light clusters with dum dum
I found problems/ blockages in all the above areas. I think that's about all of the trouble areas... so am keeping my fingers crossed. Due to the fact the carpets and sound proofing were so damp, I decided there was onlt one way to dry them out, so I removed everything.
I will run the car like this for a couple of weeks to see if water collects anywhere it shouldn't- it's the only way to be 100% sure I think.
Sunroof
Fuel filler neck
Doors
Sills
Bulkhead
![Noseats.jpg](http://i246.photobucket.com/albums/gg101/David54321_photo/Noseats.jpg)
