I have a 87 turbo and have had it for about 8 years.
When looking at it from the rear it always looked like it dipped slightly to the left. I always put this down to the fact that the guy I bought it from was a very large and had worn out the suspension!!
Anyway about 3 years ago (having driven it for 5) I replaced the rear dampers with new ones from berlyn services. The problem was the same, so I then thought that I would take the front ones off to check. I got round to this about a year later and when I took them off they were both different! Both in length and spring diameter. One had two yellow blobs on it and the other shorter one had one red one.
It was then I discovered (after some looking) it had been in a bump and somebody had replace the parts but not known the difference between different turbo years (or was the strut from a LUX?) like me.
I bought some Sachs replacement inserts from Berlyn Services (to fit the 87 turbo) but needed some springs as mine were odd. I also got some bits that I was missing for the odd leg (gaiter/stop bung/and top cap thing) from a Porsche dealer so I am inclined to think that the inserts I got from Berlyn were correct in diameter.
The springs are the problems though. I bought some lowered ones which were the correct diameter for the inserts. I put these on but it looked silly (as the rear was in the air and I didn't know how to lower the back). I took them off and bought some springs on ebay from a 91 turbo. They arrived and as soon as I opened the box I knew they wouldn't fit. They were too narrow.
The search continued and I bought a complete set of turbo struts and springs on ebay for £15. Collected them and they had the same springs on that I already had!! Still a deal is a deal so I bought them and put them on.
Took the car for an MOT and it passed (with NO problems after not being driven for 2.5 years try that with another car..) trouble is it looks a bit high on the front and the suspension is a lot harder than I remember.
The questions I am getting to are:
What is the spring diameter and height supposed to be for an 87 turbo
What is the distance from the top of the front wheel arch to the top of the wheel (assuming 16" wheels and 205/50 tyres)
The inserts I bought from Berlyn (Sachs) fitted the old spring with the 2 yellow dots on. The diameter is approx 13cm not sure on the length. Anyone know as I am sure these are what I am looking for.
The springs I bought on ebay have 2 grey dots on them and are approx 10.5cm in diameter and 34 cm long. I think they are the same as the ones I have fitted now, but don't know what colour is on them.
Does it matter what age shocks are fitted? I only want to put the new Sachs ones on as they have done zero miles.
Thanks for your help (and patience in reading this far!)
I have loads more questions but will trawl around the posts before I post more..
