My CDR24 has no display read out, is this a common problem, how can it be solved. I get the station setting in the rev counter but that is all. 2005 Boxster
Have just bought 987 boxster and the radio CDR24 has no read out
- Thread starter Whitehouse
richardjjs1
If you get a read out on the dash does the radio work
richardjjs1
If you have just bought the car may I suggest the following
Check all your drain holes - 4 around battery and 2 under roof (Lift it about 4 - 5" from Windscreen
Water ingress can cause problems with ECU under passenger seat
And make sure leaves between Condensor and Radiator are cleared (Front Bumper off) These arte little jobs that can save a foryune
Radio works perfectly but cannot access the lcd readout to programme phone etc.
richardjjs1
Radio a bit of a sod to get at
On either side down towards footwell is a small triangle of carpet about 6" x 6" x 6" Torx screw in middle
Behind this are two smaller torx screws - remove these and you can pull off the carpet covered covers
Then on the passenger side of the there is a small securing screw that needs removing
You can then remove the radio
Maybe another ember will have the same radio
Get on BoXa.net, do a search or better still join up and ask for help. Best and friendliest source of info on all things Boxster. Good luck...i'll see you there.
