Haynes Manual
Thanks James, that'll help sell it [:mad:].
This one of course is worth a bit more as it's a "very pleasurable addition and creating much happiness to you and family for whatever the rest of your life and all around it with including extra fine wonderful superbly manual haynes Porsh workshopping"...
as they'd say on e-bay, [:D]
Phil
We all take the mick out of Haynes manuals, but it's still worth buying one for any car you have (I have one for the 944 myself).
As mentioned in the other thread, it serves as a handy reminder of all the cars you have ever owned [:)]
It's also handy for finding out how various bits of trim should be removed etc. Well worth spending the few quid they cost on one, although it's also a good idea to have a real workshop manual if you can get hold of one.
I seem to recal we had a thread "101 Things to do with a 944 Haynes Manual" or something like.
A search may prove enlightening. [8|]
HAYNES' MANUAL - THE REAL MEANINGS
For those of us that have ever used a Haynes Manual in attempting home
maintenance of a car.
For those who have not used a Haynes Manual, these are the books aimed at
car-owners who want to fix their own cars and which keep qualified mechanics
in paid employment putting things right afterwards.
They are chock full of photos, diagrams and step-by-step instructions which
are obvious if you are a fully qualified motor mechanic, but which are
frighteningly sparse on detail for the average Joe in the street who wants
to change a set of spark plugs on a 1981 VW Polo ....
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips (adjustable wrench) then beat repeatedly
with hammer anticlockwise. You do know which way is anticlockwise, don't
you?
Haynes: Should remove easily.
Translation: Will be corroded into place ... clamp with adjustable wrench
then beat repeatedly with a hammer.
Haynes: This is a snug fit.
Translation: You will skin your knuckles! ... Clamp with adjustable wrench
then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Not a hope in hell matey! ... Clamp with adjustable wrench then
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now you
are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Ease ...
Translation: Apply superhuman strength to ...
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to
dig out the bayonet part and remaining glass shards.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing then re-check the manual because what you are doing now cannot
be considered "lightly".
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating (simple).
Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, ikkle number... but you also thought that the wiring diagram was a map
of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating (intermediate).
Translation: Make sure you won't need your car for a couple of days and that
your AA cover includes Home Start.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating (expert).
Translation: OK - but don't expect us to ride it afterwards!!!
Translation #2: Don't ever carry your loved ones in it again and don't
mention it to your insurance company.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search for it in the dark corner of the
garage whilst muttering "******" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking
at, then declare in a loud knowing voice to your wife "Yep, as I thought,
it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking feeling in the pit of your stomach has subsided, you can
start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Using a suitable drift or pin-punch...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Translation #2: Heat up until glowing red, if it still doesn't come undone
use a hacksaw.
Translation: Unless you have a blast furnace, don't bother. Clamp with
adjustable wrench then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to
do!
Haynes: Remove oil filter using an oil filter chain wrench or length of
bicycle chain.
Translation: Stick a screwdriver through it and beat handle repeatedly with
a hammer.
Haynes: Replace old gasket with a new one.
Translation: I know I've got a tube of Krazy Glue around here somewhere.
Haynes: Grease well before refitting.
Translation: Spend an hour searching for your tub of grease before chancing
upon a bottle of washing-up liquid (dish soap). Wipe some congealed washing
up liquid from the dispenser nozzle and use that since it's got a similar
texture and will probably get you to Halfords to buy some Castrol grease.
Haynes: See illustration for details
Translation: None of the illustrations notes will match the pictured
exploded, numbered parts. The unit illustrated is from a previous or variant
model. The actual location of the unit is never given. The best one I
encountered was how to change a brake sensor in a Ford Fiesta Popular Plus.
The photo showing the location of the unit failed to mention the crucial
detail of whether the item was located in the engine compartment or inside
the car ..... and the helpful photo of what the thing looked like didn't
give the reader any clues!
HAYNES GUIDE TO TOOLS OF THE TRADE
HAMMER: Originally employed as a weapon of war, the hammer is nowadays used
as a kind of divining rod to locate expensive parts not far from the object
we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on boxes
containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their
holes until you die of old age, but it also works great for drilling
mounting holes just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board princ
iple. It transforms human energy into a crooked, unpredictable motion, and
the more you attempt to influence its course, the more dismal your future
becomes.
MOLE-GRIPS/ADJUSTABLE WRENCH: Used to round off bolt heads. If nothing else
is available, they can also be used to transfer intense welding heat to the
palm of your hand.
OXYACETELENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire. Also handy for igniting the grease inside a
brake-drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older cars and motorcycles, they
are now used mainly for impersonating that 9/16 or 1/2 socket you've been
searching for for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal
bar stock out of your hands so that it smacks you in the chest and flings
your beer across the room, splattering it against that freshly painted part
you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprint whorls and
hard-earned guitar callouses in about the time it takes you to say, "F...."
HYDRAULIC FLOOR JACK: Used for lowering car to the ground after you have
installed your new front disk brake setup, trapping the jack handle firmly
under the front wing.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a
hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbour to see if he has another hydraulic
floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-doo off your boot.
BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten
times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and brake lines you may have forgotten to
disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that
inexplicably has an accurately machined screwdriver tip on the end without
the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from
a car battery to the inside of your toolbox after determining that your
battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
INSPECTION LIGHT: The mechanic's own tanning booth. Sometimes called a drop
light, it is a good source of vitamin D, "the sunshine vitamin," which is
not otherwise found under cars at night. Health benefits aside, its main
purpose is to consume 40-watt light bulbs at about the same rate as 105-mm
howitzer shells during the Battle of the Bulge. More often dark than light,
its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-
and-tin oil cans and splash oil on your shirt; can also be used, as the name
implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a fossil-fuel
burning power plant 200 miles away and transforms it into compressed air
that travels by hose to a pneumatic impact wrench that grips rusty bolts
last tightened 30 years ago by someone in Dagenham, and rounds them off.
PRY (CROW) BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 pence part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
Mike[:'(]
If you still want a Haynes Manual look under FICTION in your local library. Better stll send me a A5 sae and I will send you a manual on disc. I have sent my address to you by email.
All so true, but you have to have done it to really appreciate it. [&:]
What is even more exciting is the 944 Haynes manual is American so half of it is disclaimers and the other half says "Get a mechanic as this might cause injury so we aren't going to tell you how to do it just in case you try to sue us."
Also.....it is printed on disgusting cheap recycled paper so the pictures accompanying the limited tasks they do explain are illegible. This does make it better for soaking the oil off your hands while reading it.
I'd go with Geoff's offer - although CD's are rubbish at soaking up oil. [:D]
Cheers for the replies Geoff I will take you up on your offer, thanks
I have always found them to be quite handy although I have only owned fords before, took my whole engine apart and rebuilt it following the haynes manual along with some knowledge. Although A 5 year old could rebuild a ford engine
Its handy for small jobs and maybe getting n idea as to whats involved.
Simon
LOL
I have a brand new shiny Haynes infront of me now (80035) which is meant to be for the 944 '83-'89 including Turbo....
...there are no mentions of turbos whatsoever it all relates to a standard '83 944.....bloody americans...
...and its a softback (English Haynes have always been hardback) - whats that all about?? It's like toilet paper (in appearance and potential usage!) such a waste of time and money!
