sbloxxy
My 944 S2 is testing my patience at the minute. What do you make of this: (some of thses symptons may or may not be related:
A few days ago, I noticed the temperaute gauge creeping up, then as either the thermostat opened or the fans cut in, it dropped again only to creep up again til the cycle repeated itself. Checked the coolant level which was very low, even though I had checked this a couple of days before. Topped it up but 60 miles or so later and I've got the same problem and the coolant level is low again. While checking for leaks from the system (none that I can see) and with the engine still hot, I noticed a fair amount of smoke/steam escaping from the oil filler cap. Upon restarting the car, it struggled as though fighting against compression and I detected a small misfire, which cleared a few seconds later. What do you reckon? Does this sound like a headgasket problem or am I barking up the wrong tree? If it is head gasket, what sort of job is that to do?
