Head lamps for Boxster 1997
- Thread starter Ellie
Charlie
ORIGINAL: Charlie McLaughlin
Hi, I dont believe the early cars had the facility to switch the "beams". In these cases, you just need to apply the stick on headlamp kits, that you can buy for about £10 in Halfords.....
Charlie
Take a note of the shape on the kit and on subsequent trips you can make your own out of insulating tape - saved myself loads over the years
Fred Hindle
There is a pair on there at the moment for 290 euros.
I bought a pair from there last year. Didn't want the beam defectors welding themselves to the lenses.
Cheers,
LUCIO.981
I know it doesn't help with yours being a 986 but if it does have a switch it's easy to do!
Headlight unit out, back off like you do to change a bulb & flick the switch accross, job done!
It's definitely a lot better than having sticky convertors on to remove on your return to the U.K!
Fred Hindle
Cheers,
