header and de-cats
- Thread starter Nick_USA
You should be OK without the extra cable, but it depends on where the manufacturer has put the sensor holes. Some words of advice on the fitting; make sure that you soak and I mean really soak the header bolts in a penetrating spray before attempting to undo them. These bolts corrode like crazy and are prone to snapping and the last thing you want to do is to drill them out. If you can spare the expense replace the bolts when you replace the headers. As for running catless pipes you should also be aware that you may get check engine lights; Not something you can really avoid but there is always a downside to many performance enhancing products.ORIGINAL: MARCN7798 hi nick, yes new headers and catless pipes? cheetah mk 11 de-cats, stainless headers, just want to know what to expect before i decide to fit the things
nwhear
I replaced the headers on my car and fitted a replacement Oettle style back box. I reckon you are in for a surprise, and not in a good way []ORIGINAL: MARCN7798 just put the cats back in, simples
You could say the same for NOT fitting 'N' rated tyres. My insurance company said there wasn't any problem if I was changing the exhaust for a 'Stainless Steel' version, so that's what I did [] My argument would be there was no performance or aesthetic gain simply greater longevity, simples []ORIGINAL: nwhear Unless the insurance company have been informed of the mod the insurace cover will be void. Then of course the same would alpply when you put the cat back on - you would have to inform the insurance company again as the car would still not be factory spec. Technically "simples" legally not quite so!
nwhear
We're back to the not fitting 'N' rated tyres again aren't we. Anyway I didn't say there was no performance gain just that i would argue there wasn't. Obviously with a simple cat and backbox change i have been capatulted into 997 GT3RS territory, at least that is what it sounds like to me[] My car now sounds fantastic which is why I did it, as to the insurance company not covering it, I have the date, time and name of the insurance advisor and can quote verbatim what was said regarding the exhaust mods during our conversation. Personally there are other things that would keep me awake at night but since I have done the mods it's a bit late, maybe I should drive more carefully[8|] As for wiggle room with insurance companies, now I know you are just being silly, simples[]ORIGINAL: nwhear But if there is no performance or aesthetic gain one is inclined to ask what is the point? Surely you could get a stainless system INCLUDING a cat then you would get the longevity without pumping out all those nasty nitrogen compounds that are actually quite toxic. I still think you give you insurance company just the wriggle room they would need if the need arose. They might then be in a position to say "not covered sir - simples"
