headlamp adjuster
Alpine
my headlight adjuster (the one that works by turning the wheel on the console) has stopped working on one headlight.
Does anyone know if it is a quick fix?
It's a small black box about 70mm x 50mm at the side of the headlamp, pop the bonnet raise the lights & you should see it.
Your fuse may be blown, the motors could be faulty, the wiring may be broken, the adjuster switch may be faulty.
But they definitely won't work if the motors are not plugged in.
