Hi All,
Has anyone experience of the wiring for the motors that adjust the headlamp beam aim (for when you're loaded with a boot full of whatever...)?
Mine don't work, so I've done the checks in the manual. Each motor plug has wires 1,2 & 3 and should show battery voltage across 1 & 3, and a control voltage across 1 & 2. On the Right cable I get 12v on 1&3, but with the switch set at "1", no control voltage on 1&2. On the left plug I get nowt, nada, nuffink.
I can see that the cable to the left side plug heads back across behind the front bumper panel towards the right, so I'm hoping that both cables join at a connector somewhere on the right hand side, but with the headlamp pop-up motor and the washer bottle on that side it's hard to see much. I'm guessing that this is another of those faults caused by years of cable flexing as the lights go up and down, so If I can figure out where the cables run I'd like to rewire them end-to-end.
All clues as to cable routing and connecting points gratefully received.
