Thank you very much for the post. I'm in Canada with a 91 944 S2 RoW car and no one has experience with this system as it was not provided on North American models. I've hanged my headlights from left hand traffic to right hand traffic using a similar procedure as you described. My articulates were brittle so I broke them off and used new ones. I didn't remove the motor from the retaining frame as it looked like a lot of disassembly would be required and the motor would have to be back in place before the headlight could be mounted. I used a 1x1x20 cm stick of hardwood to push the articulates over the stud heads though (I'm old and don't have the hand strength I used to. Using the piece of wood allowed me to push with my thigh while firmly backing up the retaining frame with my hands as I was afraid of breakage.
Some additional questions please.
1. On the retaining frame, the top left stud has a knurled shaft and no "screw head" to support adjustment. Does this shaft actually turn in the retaining frame for coarse adjustments or is it fixed in place?
2. On one headlight, the lower threaded stud that attaches to the leveling motor is screwed in all the way - on the other headlight, the screw can be turned in or out. Are these studs integrated with the motor or are they removable?
The parts book for these show only two threaded adjusters per pair of headlights and show the leveling motors with the adjusters assembled.
3. You mention using new retaining frames each time as reusing old plates was a problem. Can you elaborate please? Maybe I was lucky as only one stud had any corrosion on the ball end and a little steel wool cleaned it up very well.
Finally - a moan about how Porsche abuses us. You say articulates are about 30p each - when I special ordered they cost me $4.71 Canadian each. 6 articulates and 2 headlights set me back approx $450 Canadian. As you can imagine, I don't want to have to buy retaining frames also.
Thanks again for the excellent write-up.
Bruce Nelson
Edmonton, AB, Canada
bmnelsc@telus.net
