911/996 targa 2002
headlamp problem
my main beam headlamps are not working - happened simultaneously to both sides suddenly one day
i can 'flash' to high beam but cannot set to permanent high beam
all other lights are fine
no warning lights on dashboard - shows as high beam when flashed but not when supposedly set to permanant
i have checked removed and refitted the headlamp units and saw no problems with wiring or lamps
i have checked the fuses for the main beam lights
i have removed the headlamp unit recently to change beam for european driving and everything was fine
for a while before this problem occoured - i have now reset to UK side and this had no effect
any ideas ? thanks
headlamp problem
any ideas ? thanks
