headlamp washers
Hi,
Got my windscreen washers going!
However my headlamp ones dont work.
Where is the motor for these?
thanks
Amolak
Both the pumps are on the washer bottle behind/under the offside headlamp (Pop them up for easier access). You can see one of the pumps straight away, the other is further down and hidden slightly. I can't remember which is which [&:]
Forget about them for another 6 years? [:eek:]
(Test the pump, switch and tubing. Nice simple problem-solving task. There may be a relay in there somewhere as well to make things a little more interesting.)
I think a more accurate description is 'Headlamp Wetters' I haven't seen any discernable benefit from using them
