Rikki
Hi there,
Got a small problem with my Boxster. (2004 Boxster S - 47k on clock)
If the temp outside is below 5 and I turn my headlamps on (xenon/HID factory fitted) sometimes only the side lights will pop on but as you see with a faulty started in a fluro tube light the near side headlight flickers at a rate of around once per second. Not full power but a small blip.
If I leave the side lights on for 20+ seconds and then turn the switch back and forth it seems to kick the headlamps in most of the time making me think its temperature related.
Its both sides that dont kick in but only the near side has the little flicker.
I know the switches are problematic but I dont think thats the issue in this case.
Im also not sure what it could be as I would think if one ballast pack was dead or dying then the other headlamp would work ok.
Any advice for an auto electrical newbie?
Rik
Rik
