Significant embarrassment. [&o] On returning from Porsche Club this evening I turned off Beaky's headlamps and they stayed up [
Have checked fuse 2 and it looks OK. It is 25 amp so would be pretty obvious if it had gone.
Have checked the motor connections and they look OK but haven't had a chance to put a tester on them.
Have pulled the relay on the motor and will replace as I'm hoping it is this which will have gone - again not tested the battery in my multimeter is flat [
]. If I had a wire with spade connections on either end which terminals should I plug in to and would the connection only be periodic switched off by the position of the motor?
As the headlamp motor must only receive a periodic supply to lift or drop is there a further switch control box some where or what else could it be?
