Headlight Adjustment
MattDC2
Hi,
I'm looking to lower the headlight beam on my Gen 1 C2S, has anyone here done this? Following the instruction manual I've found the relevant access hole, but I don't think the hexagon socket tool in the toolkit fits. Is it just a long allen key I need?
Cheers,
Matt
Yes, I found a short Allen key that fits into the hexagon socket tool, cut a straight piece of the Allen key off and place it in the end of the socket tool.
Tip: to cut an Allen key use a bench grinder.
Or, I have been able to use a long screwdriver if it fits snugly into the hole. Make sure its snug otherwise you will round the hole which is plastic.
A flat blade worked fine for me.
