Headlight cleaning
- Thread starter 964rh
Neil
Hope this helps ,
G
waiting for a nice day to wash and polish the car befcrating an avatar![:-]
Changing 911 headlights/lenses/bulbs"¦"¦.
Here's how :
Remove the outer ring with the crosshead screw (at 6 o'clock).
Remove the headlight with the flathead screw (also at 6 o'clock) - DON'T touch the other 2 screws (adjusters)
Unplug the 3point headlight wires, the earth, the sidelight & the vacuum pipe.
Remove the light.
For a guide to the clips in the next bit, remove the other light now also....same method.
Doing one at a time, remove the clips around the lip at the back, placing them down to form a circle (in roughly the same place).
Mark the adjusters with a permanent marker, on either side of the plastic piece.
Unclip the adjuster with the black plastic cylinder by prising it with a flathead screwdriver.
Unwind the other adjuster (CHECK you've marked it on the thread) - It may be possible to unclip this, but didn't want to break mine.
The light backing should now be free enough to remove the lense.
Fit a new seal (flat thin one) to the new lense (smooth side on the glass) around the outer lip.
The other seal fits on the car (the old one will still be in position).
Refit the lense to the light unit
Ensure the lense it vertically aligned by carefully turning over & adjusting the marks at 6 o'clock.
Refit all the clips, using the other light as a guide (the light units are identical - only variation is for RHD & LHD).
Clip in the removed adjuster & correctly adjust the one you backed off.
Repeat the process for the other unit
Fit the new outer seals on the car, around the headlight pods.
Refit the lights to the car (don't forget the vacuum pipes).
Whole thing took about 2 hours sat on the lounge floor, watching telly, so could be done in an hour, easily.
Rgds,
Jon
