Headlight help please
- Thread starter sloaner
paulf968
NB Mind you the other arm you mention is called a 'swivel frame' and the issue here seems to be whether you need one of those (looks expensive) as the spherical ball has snapped off in you pictured piece. So, can the remaining bit be unscrewed from the swivel frame - thereby allowing a replacement.
sloaner
ORIGINAL: Big Dave
You will poss need one of the adj arms as pictured , as the ball will be difficult to remove from the socket. This is the problem i had...
Hi Big Dave,
Thanks for the reply - yes, i imagine i will need a new arm. Where did you get yours from? Did you have to buy the full fixing unit? Do you still have the part number by any chance?
Mark
sloaner
ORIGINAL: paulf968
I have just looked on the Parts list and almost everything is individually marked -- so as Dave infers, decide what it is you want speak to your Porsche Dealer and he will order it up however small. (I cannot speak highly enough of the parts guys I go to at Porsche Silverstone - they put as much trouble into sourcing the correct £1 bolt as bigger expensisve stuff)
Thanks for that Paul. I have sent you a pm.
Mark
paulf968
Hi - I think you have returning PM's disabled on your profuile so have to reply here.
I suggest that you download the full catalogue here:
http://www.porsche.com/uk/accessoriesandservice/classic/genuineparts/originalpartscatalogue/ Then look under the 'Body' section for the headlight mechanisms -- all will be revealed! Best of luck in sorting it. Paul
Big Dave
Sorry ive no part numbers as it must be around 3 or more years go that i did the repair...
Got the parts from Porsche, my local dealer Kendal OPC...
Have a look on the parts diagram + im sure youl be able to find it....
Oh and when youve fixed it, make sure the ball + sockets are well greased..
