Headlight lens replacement on 964
Yoda
Hi. Has anyone done this and is it relatively straight forward? Need to replace both my headlamp lenses due to stone chips and thought I would do it myself if easy. If not, will have to wait until the car is in the garage next.
Looks like a screw on the headlight case that has to be undone to release the outer ring and presumably the lens can be access once removed. Any info or things to look out for appreciated.
Easy enough Feroz, be carefull though as when you remove the outer ring there is another screw at the bottom which held the screw you have just removed, this comes out easily enough but can easily be damaged due to the age of the car, the nut part is a component part of the wing/headlight bowl and has been known on many occasions to be stripped of thread as its so small, sometimes needs brazing back on with a new thread.
apart from that its easy, when you remove the outer painted ring dont adjust the 2 offset screws to get at the glass as they are the beem adjusters
Yoda, it's fairly time consuming but relatively straightforward. As you have identified, the first job is to remove the screw at the bottom of the light. The cover rim can then be removed. Next you need to remove the headlamp unit. This is held in by one screw at the bottom and once removed essentially you need to pull the headlamp off, grip the edge firmly at the bottom and pull from the bottom up. It should pop out. Next disconnect the wiring connectors, maybe make a note of where they fit for reassambly if you feel the need.
Your lamps should have the vacuum adjustment and removing the lens will probably serve to lose your alignment. You can minimise this loss by recording how much screw thread is exposed behind the adjuster bolts. The actual lens is held in place by loads of peculiar spring clips. The best advice I can offer is to lie the light face down a towel and take a few photos of the back of the unit using a digital camera - the pics will help you to put the clips back in the right location.
Next unscrew the adjuster rods from the front rim, then remove the spring clips one by one - you may need some long nose pliers but they should come off ok. When the're all off the lens can be removed from the unit and the new one fitted.
To refit insert your new lens into the inner rim, push fit it onto the headlamp body, lie it lens down on the towel and refit the clips (that's the fun bit!!). Screw the adjuster rods back to where they were, then pushfit the light unit back onto the car (you may need to buy new wing to headlamp seals as the old ones often perish - new seals are only a couple of quid apeice).
Replace the outer rim and refit the screw.
The lights may need to be realigned at a garage - any garage that offers MOT services should be able to do this.
Hope this helps.
just an extra tip. You should be able to use a steel rule or tape measure to measure the length of the protruding screw thread on the adjusters(before u take them apart) this will help in refitting the lenses and you will not have to readjust too much. Or alternatively pull the adjusters out from their grommet if you can(keeping the thread unchanged).
That is because they looked daft ...................
Have you fitted them to the 993 yet?
[:D]
Thanks for all the suggestions guys, never turns out to be quite as easy as I thought (considering my mechanical competency!!). I'll give it a go over the weekend and probably get some one to fix it after.
If anyone sees a black 964 with no eyes in the sockets, please come and say hello.
