headlight loom upgrade
- Thread starter zagonda
Kongsodoken
Greg James
bmnelsc
got straight back when I had a question so he seems a stand up guy. but what did he say? It seems that you asked the same question but didn't provide the answerORIGINAL: Greg James I had this fitted today to my s2 not that bad would be easier the second one you did fitted the live to the alternator and the lights seem a lot brighter will need to go out at night to test. The guy from eBay was really helpful got straight back when I had a question so he seems a stand up guy.
Greg James
zagonda
Black Beauty
Greg James
jellytott
Bit of an old thread this, I've fitted a uprated headlight wiring loom to my 944S / 1988 and have a problem with relay buzz.
Its nicely made but have found a slight problem with it's fitted now. So with the ignition switch to Position 2 (ie not Aux engine to run but not started) then turning the headlight switch to side lights i.e first clickI get relay buzz from the relays supplied with the uprated loom, this buzz is extremely quick the sound it makes is almost like a lights on reminder.
I've spoken with the guy and suspect I have fitted a Headlight Ballast resistor fitted....does anyone know where its located ??
