Black Beauty
Gents,
For some time now I've had an issue with my headlights not being able to go up and down so after replacing the relay, the switch, the fuse, bench testing the motor, searching every page of here and the Rennlist forum for a similar issue and following the Clarks guide instructions to the letter and also reading the wiring diagrams, I can do no more hence calling on your help.
Now, I must state that I'm not an electrician, everything I've done is what I think is a worthwhile test and I openly admit that I don't know everything and that there must be something that I am missing.
So before calling the auto electrician I thought I would ask the sages on here
To help with your analysis, you can see the testing I have done in the tables below, geek alert! [
I've tested for continuity and I have continuity up to the switch for all wires, the only wire I haven't tested is the supply wire, but I figure that is ok, due to being able to trigger the motor to move by jumping the wires as shown below.
There's obviously a lot wrong with the above, but this is where my knowledge ends and hopefully yours begins
HEEEELLLLLLLLLLLLLLLLLLPPPPPPP [
