Headlight pivot bracket
- Thread starter Bondinho
Assuming you don't have a trained mouse, if in doubt, start taking things off. Most are quite easy (once you have done it once). The badge panel isn't that difficult to remove once you establish where the hidden fixings are.
Sorry I can't be more helpful as it is a long time since I played in that area. As a point though - the headlamp motor has two fuses so (unless you can establish which ones they are) best disconnect the battery. There is an internal switch in the gearbox which can make the lamp pods move of their own accord; gives you quite a thrill first time it happens and you don't want your fingers, or trained mouse, in the way if it does.
So, in summary, if it looks like you might need to remove something for access; you will.
