Headlight switch
PaulHere
I've been having a problem with the headlight rocker switch.
No problems with the sidelights on the first setting but when switching to the second main beam setting the headlights pop up but often the headlights do not switch on. However if I manipulate the switch the lights do come on.
Unfortunately they have in recent days decided to switch off without warning leaving me in the dark at speed whilst I jiggle the switch to get them back on! Not good.
How do you remove the switch for replacement/examination? I've noticed the panel in which the switch and the rotary dash brightness adjustment control are in, do I take that panel out?
Yes, you remove the panel: its all a one piece switch behind though. Switch failure is quite common in early cars. The problem is caused by the rheostat, which when turned 'down' gets too hot and leads to the failure of the whole switch.
Tell me about it. I had one fail quite catastrophicly and fill the cabin with smoke. Luckily I was yards from home and mananged to just force the switch off. Internally the switch had melted and when it all cooled down I could not move the rocker. I did post a wiring mod on the forum ages ago to bypass the contacts in the switch with a relay.
John is referring to a 2006 posting at http://www.porscheclubgbforum.com/tm.asp?m=177580&mpage=1&key=&#179839
Had the same problem last Jan, i was not so lucky and had a full dash fire. I so glad i always carry a fire ex with me. I think i would have lost the car if i did not.. Don't mess with it change it ASAP.
Hi Rob.
Nice to see you on here.
By the way thanks for your good words about PCGB on your (our) Forum.
Geoff Ives
Director
Happy days. I spent about six months slotting the switch on and off the multi plug to make the lights turn on and off. It never seemed as important as the contstant battle to keep the rain out.
Paul - is NYL 604Y known to the club? Somehow I doubt it given the state it was in when I sold it. The phone still rang off the hook though...
Hey Rob, good to see you over here, its Mav. I pop in ever now and again to see whats going on, great forum section I have to say, some good guys on here as well
