ORIGINAL: barrysmith Gentlemen, fitted hids from ebay at 68 pounds inc postage , this kit is the latest kit were the bulb does the dip beam and main beam, it has the smallest motor built into the bulb that moves a sheild approx 3mm forward on the bulb to give the bulb the dip pattern and retracts to give main beam pattern, The quility from china is simply first class and the hid power units are built to a very good standard, The job took approx 2 hours and the lights are fantastic, 6000 size for max white light. Item number on ebay 290237230559 this will get you the seller details, Delivery 5days. what ever you do make sure the wires follow the old route . DONT ASK SOME ONE TO SWITCH ON THE LIGHTS WHEN YOU ARE FITTING THEM THE HEADLIGHT FRAME WORK WILL SNAP YOUR HAND OFF SHOULD THEY BE IN THE WAY
