VYY930
Hello,
I've had a problem with my headlight washers since I bought the car (1985 Turbo) and am determined to get it fixed.
I've taken off my front bumper today to reveal the headlight washer system. It was a fairly easy job too which is always a bonus and I can see the pump and pipework.
I have tested for voltage at the plug which fits onto the pump itself and I have 12v when the lights are on and the rocker switch is pressed.
The 12v however is only present for a split second. I am right in thinking that this is "normal" to allow the pump to swirt a single jet of water at each light?
If I hold the rocker switch down the voltage does not return until I release the switch and try again.
The bumper is staying off until this is fixed so if someone can reply it will mean I can solve the problem with the washers and get back in the car and drive it!
Cheers,
Chris
Cheers,
Chris
